Ckruse
Mar 31, 2018Aspirant
Orbi RB50 performance is slow
I have the Orbi RB50 with 1 satelite. Every once in a while, my peformacne gets extremely slow. I have Fios 1G service. When Orbi is running correctly i get 500+ down/upload speeds. When it gets bogg...
- Mar 31, 2018
Apparently replacing one of the ethernet cord in the basment fixed the problem. Thanks for your help.
Mar 31, 2018Guru - Experienced User
Try the Beta FW.
Besure to factory reset the router and Satelite and set up from scratch. Very Important.
Don't enable or touch the QoS feature after setting up.
Ckruse
So I tried a factory reset and still having the same issues.
Also, not sure where to find the Beta firmware. My firmware is up to date, so I dont understand why its not working.
Not that 90 is bad, but I was pulling 500 a week ago.
