dkozinn
Oct 28, 2017Guide
Orbi RB50 periodic slow internet speeds since 2.0.0.74 - fine after reboot
Since the update to 2.0.0.74, periodically my Internet speed will slow down from the normal 65+Mbps to around 8Mbps and occasionally as slow as 1Mbps (as per speedtest.net), and I'll see ping latency...
st_shaw
Oct 28, 2017Master
I would make sure the router and sats are all on the same firmware revision. Then I'd try a factory reset of the router.
dkozinn
Oct 29, 2017Guide
I'll give this a shot. If I backup & restore, will that restore potentially cause whatever issues I'm having now to return?
- st_shawOct 29, 2017Master
I can't say for sure, but I would setup from scratch if it's not too much trouble. You can always make a backup and only use it if necessary.
- grendelrtOct 29, 2017Guide
I am having this same exact issue. A reboot fixes the issue for a little bit but it comes back.
- cyberprashantOct 29, 2017Luminary
seems to be better after implicit beamforming switched OFF (unticked under advanced wireless and and moved from channel 11 to 6 (not sure which of these fixed it). Mu-MIMO and fast roaming are still ON (2.0.0.74)
- dkozinnNov 11, 2017Guide
Sorry for the delayed response, I needed a time when nobody else needed the network to do the setup.
I did a factory reset and I did reload the configuration settings from a save. I'm going to give it a day or so (this has been happening pretty frequently, so I'd certainly see it at some point over the weekend) and if it comes back, I'll rebuild from scratch. I took screenshots of all the settings so it'll be tedious but I have the info. I'll get back in another couple of days as to whether this worked.
- dkozinnNov 19, 2017Guide
Unfortunately, after the reset to factory default (from the Backup Settings tab) and reloading the saved config, there was no change in behavior. I then did a reset again and this time rebuilt the configuration from scratch. That didn't help either. Within 24 hours (could have been less, I wasn't constantly checking) it had reverted back down to the slow speeds again.
What do I do now? Is there another way to some kind of lower-level reset that might help?
Is there any chance this could be related to the latest firmware upgrade, since I'm pretty sure that's when I started seeing this issue. Is there a way for me to revert back? This is getting pretty annoying.
