dkozinn
Oct 28, 2017Guide
Orbi RB50 periodic slow internet speeds since 2.0.0.74 - fine after reboot
Since the update to 2.0.0.74, periodically my Internet speed will slow down from the normal 65+Mbps to around 8Mbps and occasionally as slow as 1Mbps (as per speedtest.net), and I'll see ping latency...
st_shaw
Oct 29, 2017Master
I can't say for sure, but I would setup from scratch if it's not too much trouble. You can always make a backup and only use it if necessary.
grendelrt
Oct 29, 2017Guide
I am having this same exact issue. A reboot fixes the issue for a little bit but it comes back.
- cyberprashantOct 29, 2017Luminary
seems to be better after implicit beamforming switched OFF (unticked under advanced wireless and and moved from channel 11 to 6 (not sure which of these fixed it). Mu-MIMO and fast roaming are still ON (2.0.0.74)
- grendelrtOct 30, 2017GuideDid you apply that while the issue was occurring?
