dkozinn
Oct 28, 2017Guide
Orbi RB50 periodic slow internet speeds since 2.0.0.74 - fine after reboot
Since the update to 2.0.0.74, periodically my Internet speed will slow down from the normal 65+Mbps to around 8Mbps and occasionally as slow as 1Mbps (as per speedtest.net), and I'll see ping latency...
peekki
Apr 02, 2018Aspirant
I have exactly same issue with my Orbi setup with one router and two satellites. After reboot the system is fast but slows down quite soon. The discussion in this thread ended couple of months ago but was there any solution to the problem?
Apr 02, 2018Guru - Experienced User
If you have a RBK50 or RBR50 series kits, please try the beta FW:
Do a factory reset on both router and Satellite then set up from scratch.
peekkiwrote:I have exactly same issue with my Orbi setup with one router and two satellites. After reboot the system is fast but slows down quite soon. The discussion in this thread ended couple of months ago but was there any solution to the problem?
