Chipsky's avatar
Chipsky
Initiate
Jun 26, 2018
Orbi RB50 Remote Management Problem
I'd previously set up remote management and it was working. The firmware update (0.18) went wonky and I had to factory reset. Once I set everything back up and it was working correctly, I turned on r...
  • DarrenM's avatar
    Jun 26, 2018
    Try removing the orbi network from the phone and then connecting to the wireless again then open the app again and see if it pick up the system.
    DarrenM
