Tnrchrds
Jul 12, 2018Aspirant
Orbi RB50 remote management trouble
I just changed from Cable internet to Fiber Optic. Most of my devices are working but the Remote Management app says “Internet Offline”
the speedtest on the app says it is connected because I ...
Jul 12, 2018Guru - Experienced User
What was the prior ISP modem Mfr and model#?
What is the new ISP modem/ONT Mfr and model#?
You may need to factory reset the router and set up from scratch with the new ISP modem/ONT.
- TnrchrdsJul 12, 2018Aspirant
Old modem. Ubee model DDW366
new modem. Arris model bgw210
- FURRYe38Jul 12, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.- TnrchrdsJul 12, 2018Aspirant
That sounds great, but I have no idea how to do those things. The AT&T installer said he disabled the Wi-fi on the modem since I had the Orbi router.
