Tnrchrds
Jul 12, 2018Aspirant
Orbi RB50 remote management trouble
I just changed from Cable internet to Fiber Optic. Most of my devices are working but the Remote Management app says “Internet Offline”
the speedtest on the app says it is connected because I ...
Tnrchrds
Old modem. Ubee model DDW366
new modem. Arris model bgw210
Jul 12, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.
- TnrchrdsJul 12, 2018Aspirant
That sounds great, but I have no idea how to do those things. The AT&T installer said he disabled the Wi-fi on the modem since I had the Orbi router.
- FURRYe38Jul 12, 2018Guru - Experienced User
Ok, I would factory reset the router and have a wired PC connected to the router and walk thru the set up wizard in a browser...
