Internet1ssues
Jun 16, 2020Aspirant
ORBI RB50 Router Offline, Satellites On; Internet working on some devices not on others
Pretty much out of the blue my router starting having issues. I am losing internet connectivity on some dives, my phone for example, but other remain fine.. This issue seems to be intermittent, but wh...
tucsontico
Jun 16, 2020Virtuoso
To try to help you, the forum will need some more infor mation:
1) What firmware version is installed on the router and the satellites?
2) What is your router-satellite configuration, i.e., star or daisy-chain?
3) Have you recently made any changes to the location of the router or satellites?
4) Do you have any closeby neighbors who've changed their WiFi?
5) Have you recently changed or added any new WiFi devices?
6) What channels are your 2.4gHz and 5 gHz bands set to?
Be certain there was not an "auto update" or some errant "click to update" on your part to accidentally update firmware out of sequnce. What troubleshooting have you done so far, e.g., powercycle, factory reset, reinstall firmware, etc.?
Internet1ssues
1) What firmware version is installed on the router and the satellites? V2.5.1.16
2) What is your router-satellite configuration, i.e., star or daisy-chain? Daisy
3) Have you recently made any changes to the location of the router or satellites? No
4) Do you have any closeby neighbors who've changed their WiFi? No close neighbors, over 100yards...
5) Have you recently changed or added any new WiFi devices? Yes, MyQ was added about 2 weeks ago, the issues started about a week after.
6) What channels are your 2.4gHz and 5 gHz bands set to? Auto, 5k is 48
Several power cycles, reconfigure the router from scratch through app, but problem is still present and intermittent.
