edf
Oct 27, 2017Aspirant
orbi rb50 trying to update net gear genie getting no mountable file systems msg
DarrenM
Oct 30, 2017Sr. NETGEAR Moderator
Can you give some more detail on the issue you are having?
DarrenM
edf
Oct 30, 2017Aspirant
I was trying to update the netgear genie on my MacBook. It downloads then I get an error message that say no mountable file systems the firmware or the orbi is updated. It the netgear application that’s not updating.
- DarrenMOct 30, 2017Sr. NETGEAR Moderator
You may want to try and uninstall genie then try to download and load the updated one. And orbi does not fully work with the genie app for the best result you will want to log into the orbi via the web browser.
DarrenM
