SlowMo
Jan 09, 2018Aspirant
Orbi RB50 very slow speed (both wired and wireless)
First off, my apologies if this has already been discussed elsewhere, but I searched the threads and could not find anything that matches my issue exactly.
I am on my second Orbi system in the past week. The first one constantly dropped connections so I swapped it out with a replacement. My biggest issue is with performance. I am constantly getting around 5 Mbps download speed (Google's speed test and speedtest.net) over wifi as well as when my PC is directly connected to the Orbi router (RBR50 with firmware V2.0.0.74). This is when my Comcast Gateway is in "Bridge" mode (i.e. not acting as a router).
If I use my Comcast Gateway as a router and connect my PC directly to it, I get 275 - 290 Mbps download speed. Note that switching my Comcast Gateway to router mode does not impact Orbi's performance.
To be clear, here's my setup...
Comcast > Orbi > PC (wired and wireless) = 5 Mbps download speed
Comcast > PC (wired) = 275 Mbps download speed
Any tips or pointers? Any other info I can provide that would help?
Sort By
- tucsonticoVirtuoso
After a firmware update, if you're having issues, one of the hints mentioned previously on this forum was to do an NVRAM reset and after that do a factory default reset. When those two are complete, reconfigure your ORBI as you want but do it manually. DO NOT USE any saved configuation files to reconfigure your ORBI.
Additionally, after the reset/reconfigure DO NOT USE the built-in Speedtest on the QOS setup page. Apparently, that test mode is causing some users to have slow-downs and other anomolies. Having said all that, I'm not a WiFi expert by any stretch of the imagination. I'm merely trying to help out with some potential fixes. Overall, I've been pleased with the performance of the ORBI system in my environment. There are still issues in my system too but nowhere near as many as other folks continue to report. One final note, I am running firmware version 2.0.0.74. It has been quite stable and gives me good wired and WiFi speeds. Good luck!
- SlowMoAspirant
I appreciate the suggestions, but after trying that plus a dozen other things (including swapping wires, changing parameters, loading old & new firmware), I had zero success. I put in Orbi and my download speed (connected) is still around 5 Mbps. I swap out my old D-Link router and I get 275 Mbps. Total garbage. Return #2 and will try Eero now.
- SlowMoAspirant
Oh yeah, and it stopped being able to find my satellite and the phone app stopped working with a message saying my router model wasn't supported. If it were the first one then I would be more forgiving but seeing as I already returned it once before for another set of problems, I'm done.
