Blueridger
May 08, 2019Aspirant
Orbi RB50 won't let me update apps
All,
I bought my RBR50 (and satellite) in November 2018, and installed in a fios house w/o incident. The unit's internet connection became intermittent last night. I reset the unit, and that mostly...
- May 09, 2019
Netgear somehow created two separated threads out of my question. Here is the response I posted last night after the problem was resolved:
Believe it or not, Netgear customer service solved the problem. The problem was IP address conflict between my router and Fios. I couldn't access the router b/c I stupidly followed their directions to log in (admin/password). It turns out that the password was the new one I assigned to the router. Once I entered that, the unit automatically assigned itself a new IP address, and all was golden.
Thanks everyone!
Blueridger
Update: I have the correct password, the router simply is not letting me log in. I am connected to the internet through the router.
Help!!
May 09, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
Help!!
- BlueridgerMay 09, 2019Aspirant
Netgear helped me solve the problem. I'm set - thanks!
- FURRYe38May 09, 2019Guru - Experienced User
Please post on details of how they helped you fix this so others will benefit should others have similar problem. Thank you.
Thanks everyone!
