comainusa
Oct 15, 2020Tutor
Orbi RB53 - satellite disconnections
Hi everyone, trying to troubleshoot an issue with my RB53 Orbi system. One of the satellites frequently shows as being disconnected and without an IP address in the Admin/Connected Devices page...
comainusa
Oct 19, 2020Tutor
Thanks for the suggestions. Will try and see ...
Oct 19, 2020Guru - Experienced User
I would direct connect the RBS to the back of the RBR by passing the switch as a temporary check to see if the behavior changes.
I see your switch model is EOL from Cisco.
Not sure if this is a managed switch. I believe i maybe. Check to see if any IGMP protocols are enabled on the switch if it's managed. If this is enabled, disable this.
comainusa wrote:Thanks for the suggestions. Will try and see ...
