DaveElson
Oct 01, 2022Tutor
Orbi RBK -13 Streams internet fine to TV's - issue accessing internet with Win 11 PC's
Hello I have a Netgear modem/router c6300 which did not produce quite a strong enough signal in our new home. I saw the Orbi RBK-13 package at a good price on Amazon and went for it, arriving about...
ekhalil
Oct 01, 2022Master
If you kept the Netgear modem/router c6300 in front of Orbi, then please set Orbi in AP mode. You can do this from the web GUI under >> ADVANCED >> Advanced Setup >> Router/ AP Mode.
DaveElson
Oct 01, 2022Tutor
Thank you for replying. How do I do that? I have downloaded the Orbi App but the box came with zero instructions.
The Orbi App also states the C6300 router is not supported.
I have noticed however that going into Windows Network Diagnostics and letting it do it's work - it fixes the network adapter or access point and everything is fine. It doesn't seem to last long however.
- ekhalilOct 01, 2022MasterPlease use a browser on any computer attached to Orbi and go to orbilogin.com and enter user name (admin) and the admin password that you selected at setup.
The go to >> ADVANCED >> Advanced Setup >> Router/ AP Mode. And set it to AP Mode.- DaveElsonOct 02, 2022Tutor
When you say "attached to" do you mean using an ethernet cable? I tried the sites you mentioned - it sends me to Netgear and tells me my router is not supported. When I try to log in using the numbers it times out
I managed to log into change to AP. I will check out everything before I close this out.
Cheers.
