RainerB_Austr
Jul 26, 2020Follower
Orbi RBK 20: Network speed is getting slower after time
Hi Netgear community,
for almost 2 months we have an Orbi RBK 20 system in Use with one sattelite. The problem I am facing is, that after some time (will monitor it now to get more detailed info on that) network speed is getting really slow. As soon as I reset the system it runs smooth again.
I did already set the 2.4 and 5 Ghz Wlan to custom bands. Furthermore i did turn of the Wlan from our LTE modem. I also did activate Mu-Mimo for testing and deactivated daisy chaining as well.
Does someone have some tips for me? Further settings i can change in order to keep the desired bandwith?
One more question: What das beamforging exactly do? Really hard to find info on that. As soon as I activate it i am not able to acces our Loxone server anymore (from the Iphone/Ipad at least).
Best regards (and sorry for grammar mistakes, I am not a native speaker) from Austria,
Rainer
1 Reply
Is the Orbi system operating in Router or AP mode?What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).One User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
Has a factory reset and setup from scratch been performed since last FW update?https://www.howtogeek.com/220774/htg-explains-what-is-beamforming-on-a-wireless-router/
