Posty71
May 13, 2020Aspirant
Orbi RBK 23 - ethernet port issues on Router
we have just purchased an Orbi RBK23 pack (router plus 2 satelites). System all set up and wifi working. Attempting to connect Netgear GS105 Switch to the Ethernet port on the Router but not gettin...
tomschmidt
May 13, 2020Virtuoso
I would check your network patch cables then, as they may be faulty.
Posty71
May 14, 2020Aspirant
Cables all seam to work on other connections ie when I connect the switch to a satellite it works
Have now upgraded to manageable switch gs305e as support thinks it may be a vlan issue / still having issues so back on the help line
- FURRYe38May 14, 2020Guru - Experienced User
Be sure to disable ALL IGMP protocols on this managed switch. Also disable green ethernet features if possible.
