Posty71
May 13, 2020Aspirant
Orbi RBK 23 - ethernet port issues on Router
we have just purchased an Orbi RBK23 pack (router plus 2 satelites). System all set up and wifi working. Attempting to connect Netgear GS105 Switch to the Ethernet port on the Router but not gettin...
Posty71
May 14, 2020Aspirant
Modem provided by ISP - Arris CM 8200
Modem connected to “Internet” Port on router and switch to “Ethernet” port - only 2 ports
Have upgraded switch to GS305e today as support believes it may be an issue with VLAN but still having no luck - in q again now for support
May 14, 2020Guru - Experienced User
You're not talking the other port on the modem are you? If so, the SB8200 from arris can only use 1 port unless you have the following:
1. A router with wan aggregation. Which the RBK23 kit isn't.
2. A ISP that allows more than 1 public IP address. The vast majority don't allow more than 1 public ip address.
So just to clarify, the switch is connected to the orbi and not to the modem, correct?
