Posty71
May 13, 2020Aspirant
Orbi RBK 23 - ethernet port issues on Router
we have just purchased an Orbi RBK23 pack (router plus 2 satelites). System all set up and wifi working. Attempting to connect Netgear GS105 Switch to the Ethernet port on the Router but not gettin...
Posty71
May 14, 2020Aspirant
Cables all seam to work on other connections ie when I connect the switch to a satellite it works
Have now upgraded to manageable switch gs305e as support thinks it may be a vlan issue / still having issues so back on the help line
May 14, 2020Guru - Experienced User
Be sure to disable ALL IGMP protocols on this managed switch. Also disable green ethernet features if possible.
