Kneby2
Apr 30, 2019Aspirant
ORBI RBK 23 and router managment?
Hi all,
I`m new here and like to use your experience as help :)
Ended up on buying the RBK23-100PES (1 RBR20 with 2 RBS20) yesterday, i was thinking about going for the RBR50 (+1 sat). I ...
Apr 30, 2019Guru - Experienced User
Advanced router management needs to be done with a PC or laptop connected to the RBR using a web browser, then you can make changes to DCHP and reservations.
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here, if so, this will effect how Remote management works on the RBR. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Kneby2Apr 30, 2019Aspirant
OK, thanks.
I think i will try out option 2 then.
Nothing about Bridge mode on the modem.
I have a Genexis, Model: Platinum-7840
I do have DMZ on it, and i will point dmz to the LAN adress my modem have given to RBR20.
I got confused here, because this LAN adress my modem says is given to RBR20, is not the same as my RBR tells me it has (RBR gui has gotten a WAN adress.
Will read up on your link regarding double NAT.
Thanks again!
- FURRYe38Apr 30, 2019Guru - Experienced User
Yes, the LAN address used on the modem will be whats given to the RBR on it's WAN side port. This is the IP address that should be placed in the modems DMZ. I would set up an IP address reservation for this address ON the modem as well so the address doesn't change. :smileywink:
Good Luck.
