Kneby2
Apr 30, 2019Aspirant
ORBI RBK 23 and router managment?
Hi all,
I`m new here and like to use your experience as help :)
Ended up on buying the RBK23-100PES (1 RBR20 with 2 RBS20) yesterday, i was thinking about going for the RBR50 (+1 sat). I ...
Kneby2
OK, thanks.
I think i will try out option 2 then.
Nothing about Bridge mode on the modem.
I have a Genexis, Model: Platinum-7840
I do have DMZ on it, and i will point dmz to the LAN adress my modem have given to RBR20.
I got confused here, because this LAN adress my modem says is given to RBR20, is not the same as my RBR tells me it has (RBR gui has gotten a WAN adress.
Will read up on your link regarding double NAT.
Thanks again!
Apr 30, 2019Guru - Experienced User
Yes, the LAN address used on the modem will be whats given to the RBR on it's WAN side port. This is the IP address that should be placed in the modems DMZ. I would set up an IP address reservation for this address ON the modem as well so the address doesn't change. :smileywink:
Good Luck.
