jimng
Apr 01, 2019Aspirant
ORBI RBK 40 ring light issue
hi, can you let me know how to turn off the LED ring light? or set the wifi to off at night time.
My orbi sattelite is in my bedroom and the connection is not always good to the main unit due to hal...
Apr 01, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
What WPA security modes are you using?
Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
jimng wrote:
hi, can you let me know how to turn off the LED ring light? or set the wifi to off at night time. My orbi sattelite is in my bedroom and the connection is not always good to the main unit due to hallways etc. The LED flashes blue/ purple amber non stop all night long and i have to pull the power cord to shut off. Its like a light show in my bedroom. Please let me know what to do to stop this LED Ring from lighting up. Thanks Jim
