jimng
Apr 01, 2019Aspirant
ORBI RBK 40 ring light issue
hi, can you let me know how to turn off the LED ring light? or set the wifi to off at night time.
My orbi sattelite is in my bedroom and the connection is not always good to the main unit due to hal...
jimng
Thanks. It is synced and most of the time its a long blue light. I don't mind during the day but at night time its still full blue.
I live in Hong Kong and most of the walls are cement, so the connection is not always good. 1500 sq ft home. The main unit is in the living room, the network has to passthrough a hallway, then turn right to another corridor to my sattelite unit in my bedroom. I tried many spots in the house and this is the only way to get full coverage of the mesh network. All i want is to shut off the light ring. Anyone know? i don't mind the spotchy network, i just need to get rid of the light. (some other post i read suggest that its faulty and i should return it?)
Apr 01, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
- jimngApr 01, 2019Aspirant
its only 20 feet apart but turned a corner. I'll check on the firmware and see if i can change channel
