Mejiasteven
Aug 12, 2019Aspirant
Orbi RBK 43-200 AC2200
Hello, I bought the Orbi RBK 43 (3 pack) and CM1200 modem and the modem is up and running but the Orbi can’t seem to set up. On the app it says no internet connection and doesn’t got past that. The ca...
- Aug 12, 2019
Power OFF both RBR and CM for 1 minute. Be sure you are connected to the #1 LAN port on the CM modem. Not any of the other ports. Those ports are meant for other ISP services. Or if you have a ling aggregation router which the Orbi doesn't support. Just connect the RBRs yellow LAN port to LAN Port #1 on the CM modem. Power ON the CM modem and let it sync. Be sure your CM modem was associated with the ISP services as well.
Power ON the RBR router. The top ring LED should blink WHITE, the maybe slow plusate WHITE, then turn BLUE, then it will turn OFF.
Test with a wired PC connected to the RBR. Get internet here? IF not, try a factory reset with the RBR. PRess the reset button for 15 seconds then let go. Walk thru the setup wizard with the wired PC.
IndyOpie
Aug 25, 2019Aspirant
So next phase I started getting tftp but got somehow to connect to router...I had reset whole thing and was able to upgrade firmware v2.3.5.40...reconnected all house...then was to hide power cord which meant unplugging..bad idea..now is looping again ..get intermittent access to router directly but have no clue how to break cycle as I have highest firmware...grr
Aug 25, 2019Guru - Experienced User
What all is connected to the RBR?
Sounds like you may have a device or devices that may have a IP address conflict. I would turn OFF ALL devices, Power OFF the RBR for 30 seconds, Then power back on with 1 wired PC connected to the RBR. Check internet access after the RBR is ready. I would go in to the RBRs web page and setup a IP address reservation for the PC. Disable Daisy Chain on the RBR. Power On next device. Connect and check internet access. I would go in to the RBRs web page and setup a IP address reservation for the device. Save and apply. Power on the next device and continue to check access and set a IP address reservation. Do this for all of your devices.
- IndyOpieAug 25, 2019AspirantNothing is connected...I reset to factory settings..and it will not stay connected to internet to try run setup...when I am direct wired and try to catch 30 seconds of connection..the 192.168.1.1 displays /app_index not router setup ..bout ready to throw away brick....very frustrating
- FURRYe38Aug 26, 2019Guru - Experienced User
What is the MFr and model# of the ISP modem/ONT the RBR is connected too?
Have you powered OFF the ISP modem for 30 seconds then back on then factory reset the RBR and walk thru the setup wizard with a wired PC?
I presume if this also fails to keep the RBR online, the router maybe faulty and needs to be RMAd. I recommend you contact NG support and ask about an RMA:
https://www.netgear.com/mynetgear/registration/login.aspx
