stevedavis's avatar
stevedavis
Orbi RBK 50 AC3000 - wifi connection problem
Due to all the Russian hacking, I changed the pw from the factory supplied pw to my own.  Can connect my main pc to the guest wifi but not the main wifi.  All other devices have no problem connecting to main.  I have an Xfinity router in bypass mode.  Not sure what the problem is.   Any help would be appreciated
1 Reply
  • FURRYe38's avatar
    Remove any old wifi profiles on the PC then re-connect and it should ask you to input the new PW.
