A316
Mar 25, 2019Aspirant
Orbi RBK 50 AC3000 Wifi speed
Hello everyone,
I need to ask what the top speed (Downloads) I can get through the wifi,because I have 750 mpbs plan and I get between 200 - 300 mpbs from my laptop and from 300 - 400 mpbs from iph...
- Mar 26, 2019
make contact with your ISP. Some Orbi systems are setup with ISP FW and can't use stock NG FW.
Mar 25, 2019Guru - Experienced User
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What are the wired speed test results with a wired PC connected to the base?
Wireless speeds depend on device. Max speeds seen around 400-500Mb on wireless depending upon Mfr design of the device.
A316 wrote:
Hello everyone,
I need to ask what the top speed (Downloads) I can get through the wifi,because I have 750 mpbs plan and I get between 200 - 300 mpbs from my laptop and from 300 - 400 mpbs from iphone X?!
So, anyone please help...
FW = Firmware
Ask your ISP about the modem Manufacturer and model # your using.
Wireless speeds depend on device. Max speeds seen around 400-500Mb on wireless depending upon Mfr design of the device.You'll need to contact the Mfr of these devices to see what there max wifi speeds supporting is.
- A316Mar 25, 2019Aspirant
The FW is:
Model Name Device Name Current Version Status Router RBR50 RBR50 V2.1.4.16_1.1.23 No new firmware version available. Satellite RBS50 Orbi Satellite-1 V2.1.4.16_1.1.23 No new firmware version available. Ask your ISP about the modem Manufacturer and model # your using.
About this Sorry for that but It would time to ask them and get the reply.
- FURRYe38Mar 25, 2019Guru - Experienced User
I see your behind a few versions of FW.
Maybe time to graduate to v32. You can manually download files from here:
https://www.netgear.com/support/product/RBK50.aspx#download
Note:
If you’re manually updating the firmware using a browser, you cannot update the firmware directly to v2.3.0.32. You must first update the firmware to v2.2.1.212 on the RBR. After updating the firmware v2.2.1.212 on the RBR, your Orbi router will reboot, and then you can update to v2.3.0.32. You can directly apply v32 to the RBS with out the v212 file.
If you are located in the following regions Japan (JP), Australia (AU) and Canada (CA) please hold off updating to FW 2.3.0.32
I tried to update manually but it doesn't work.However thank you for your time.
