A316
Mar 25, 2019Aspirant
Orbi RBK 50 AC3000 Wifi speed
Hello everyone,
I need to ask what the top speed (Downloads) I can get through the wifi,because I have 750 mpbs plan and I get between 200 - 300 mpbs from my laptop and from 300 - 400 mpbs from iph...
- Mar 26, 2019
make contact with your ISP. Some Orbi systems are setup with ISP FW and can't use stock NG FW.
Mar 25, 2019Guru - Experienced User
FW = Firmware
Ask your ISP about the modem Manufacturer and model # your using.
Wireless speeds depend on device. Max speeds seen around 400-500Mb on wireless depending upon Mfr design of the device.You'll need to contact the Mfr of these devices to see what there max wifi speeds supporting is.
A316
The FW is:
| Model Name | Device Name | Current Version | Status | |
| Router | RBR50 | RBR50 | V2.1.4.16_1.1.23 | No new firmware version available. |
| Satellite | RBS50 | Orbi Satellite-1 | V2.1.4.16_1.1.23 | No new firmware version available. |
About this Sorry for that but It would time to ask them and get the reply.
- FURRYe38Mar 25, 2019Guru - Experienced User
I see your behind a few versions of FW.
Maybe time to graduate to v32. You can manually download files from here:
https://www.netgear.com/support/product/RBK50.aspx#download
Note:
If you’re manually updating the firmware using a browser, you cannot update the firmware directly to v2.3.0.32. You must first update the firmware to v2.2.1.212 on the RBR. After updating the firmware v2.2.1.212 on the RBR, your Orbi router will reboot, and then you can update to v2.3.0.32. You can directly apply v32 to the RBS with out the v212 file.
If you are located in the following regions Japan (JP), Australia (AU) and Canada (CA) please hold off updating to FW 2.3.0.32
