A316
Mar 25, 2019Aspirant
Orbi RBK 50 AC3000 Wifi speed
Hello everyone,
I need to ask what the top speed (Downloads) I can get through the wifi,because I have 750 mpbs plan and I get between 200 - 300 mpbs from my laptop and from 300 - 400 mpbs from iph...
- Mar 26, 2019
make contact with your ISP. Some Orbi systems are setup with ISP FW and can't use stock NG FW.
Mar 26, 2019Guru - Experienced User
What browser are you using? Try IE11 or FF. Besure to download the FW files and unpack them from the .zip files.
What PC are you using? Windows or Mac?
A316 wrote:
I mean the manual update It give me this message :"This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product."
A316
Mar 26, 2019Aspirant
I'm using Firefox.I do unpacking the files and as I told you before It didn't work.
I'm using Windows 10 and my laptop is Dell Inspiron 15 Gaming 7567.
