HoangNa297
May 09, 2018Aspirant
Orbi RBK 50 AC3000
I'm just Update new version newest form orbi app ( V2.1.4.10) is problem,it's drop my connection .. i want to get back old firmware ...any help me downgrade ??? thanks..sorry my bad english :( !
- May 10, 2018
You could try a factory reset it has had good results for others after upgrading to this firmware.
DarenM
May 09, 2018Guru - Experienced User
Has a system reboot or a full factory reset then set up from scratch been performed?
HoangNa297
It’s only auto reboot when update finish,i’m don’t hard reset it,i’t seem this firmware not stable
- DarrenMMay 09, 2018Sr. NETGEAR Moderator
Is all of your orbi units upgraded to the 2.1.4?
DarrenM
- HoangNa297May 09, 2018AspirantYes,i have check it on my computer,both router and satellite run firmware 2.1.4.10,i’m should reset factory ?
- DarrenMMay 10, 2018Sr. NETGEAR Moderator
DarenM
