HoangNa297
May 09, 2018Aspirant
Orbi RBK 50 AC3000
I'm just Update new version newest form orbi app ( V2.1.4.10) is problem,it's drop my connection .. i want to get back old firmware ...any help me downgrade ??? thanks..sorry my bad english :( !
- May 10, 2018
You could try a factory reset it has had good results for others after upgrading to this firmware.
DarenM
HoangNa297
It’s only auto reboot when update finish,i’m don’t hard reset it,i’t seem this firmware not stable
DarrenM
May 09, 2018Sr. NETGEAR Moderator
Is all of your orbi units upgraded to the 2.1.4?
DarrenM
- HoangNa297May 09, 2018AspirantYes,i have check it on my computer,both router and satellite run firmware 2.1.4.10,i’m should reset factory ?
- DarrenMMay 10, 2018Sr. NETGEAR Moderator
DarenM
