bbyrum's avatar
bbyrum
Follower
May 18, 2018
Orbi RBK 50 AC3000
I am about to add a new RBK50 satelite and want to put it in my garage. Can this satelite withstand the heat and cold of my garage. It gets very hot in the summer (90+ degrees) and cold in the winter (10 degrees). Could the new plugin satelite work better? Thanks
1 Reply
  • Retired_Member's avatar
    Retired_Member
    orbi operating temp specs:
    0° to 40°C (32º to 104ºF)
    Maybe only put it in the garage as needed.
