Koceto
Feb 10, 2019Aspirant
Orbi RBK 50 AC3000
Hello All. Could somebody tell me if Orbi RBK 50 AC3000 is automatically switching devices connected at 2.4GHZ network to 5GHZ. I have designated devices which are working only at 2.4GHz and this kin...
Feb 11, 2019Guru - Experienced User
What is the size of your home? Sq Ft? This will ba a factor to consider when setting up a Orbi system. You may need more than just 1 satellite.
Distance between the router and satellite(s) is key as well. 30 feet is recommended in between them to begin with depending upon building materials.
Koceto
Feb 11, 2019Aspirant
Hi,
My flat is around 1800sq ft and I have 4 rooms all in 1 line. So I am planning the router to be in the room at the edge and then the satellite in the middle room . Distance in between will not be more than 15-20 feet. Walls are also regular bricks and not anything special. That's why I think that 1 Router RBR 50 and one satellite will do the job.
