Koceto
Feb 10, 2019Aspirant
Orbi RBK 50 AC3000
Hello All. Could somebody tell me if Orbi RBK 50 AC3000 is automatically switching devices connected at 2.4GHZ network to 5GHZ. I have designated devices which are working only at 2.4GHz and this kin...
Koceto
Feb 11, 2019Aspirant
Hi,
My flat is around 1800sq feet and I have 4 rooms in total aligned some how in a line. I am planning to place the RBR 50 in one of the rooms at the end and then the satellite in the middle room no more than 15-20 feet away. That's why I think that this configuration will work. Walls are just regular bricks and nothing special.
Chuck_M
Feb 11, 2019Mentor
The RBK50 kit... which includes 1 RBR50 router and 1 RBS50 satellite will work perfectly for your scenario. It is precisely the same I originally installed.
I have since added two additional satellites to reach some distant parts of the property.
Two of my RBS50's are hardwired via ethernet cable back to the RBR50. The third satellite uses wireless backhaul.
I do have a netgear switch in there somewhere to give me additional wired devices.
I have at any moment well over 50 devices active.
This includes
A very large sonos constellation -- including
.Play 1s (about 10)
.Play 3s (4)
.Play Bar
.Sonos Boost
.Sonos Amp
Nest doorbell
Nest smoke detector
Nest thermostat
Hue lights
About 7 Samsung TVs
4 x computers
1 x Pentair Pool controller
Roomba
1 WD Mycloud Mirror NAS
Bluerays (multiple)
Petcube
Samsung security system w/16 cameras
Alarm system
Rachio irrigation system
Chamberlain garage door openers
Ipads (my wife!)
Iphone (my wife!)
Androids
Alexa Show
Alexa Dots (5 or more)
Alexa Echos
Works like a champ at max speed.
- KocetoFeb 11, 2019AspirantWow ....wow .....wow......Chuck_M....you blow my mind. So many things you have connected. I will probably have 1/3 of that. I am definitely going for this configuration.
You said that you have Alexa! Can you please tell me when you want Alexa to complete some Task do you Say " Alexa tell Orbi .....and then the command " or you just say "Alexa ......and directly you say the comand" for example :
Alexa tell Orbi to switch off bedroom lights.
Or
Alexa switch off bedroom lights.- Chuck_MFeb 11, 2019Mentor
"Alexa turn off all lights"
"Alexa turn off the bedroom lights"
"Alexa make the den blue"
"Alexa, set the dining room to 50%"
"Alexa, lock the doors"
"Alexa, show me the front door"
"Alexa, play country music in the gazebo"
"Alexa, stop the music"
Orbi doesnt play in any Alexa commands
Msg me off line if you want further tips on setting up alexa to maximize performance and usability.
- ekhalilFeb 11, 2019Master
...... and also, :)
- "Alexa, ask NETGEAR to enable the guest network."
- "Alexa, ask NETGEAR to disable the guest network."
- "Alexa, ask NETGEAR what's my guest WiFi password?"
- "Alexa, ask NETGEAR to reboot my router."
- "Alexa, ask NETGEAR to send me my WiFi settings."
- "Alexa, ask NETGEAR to enable traffic meter."
- "Alexa, ask NETGEAR to disable traffic meter."
- "Alexa, ask NETGEAR what's my ISP speed?"
- "Alexa, ask NETGEAR what's my internet usage?"
More details here:
