jhjorten
Jun 25, 2019Aspirant
ORBI RBK 50 ATT Arris BWG 210 and Sonos - Cannot play music error 701
I have seen many posts on this and was also told by Sonos that this particular issue could not be resolved until Netgear delivered a firmware update. Reaching out to see if anyone has been able to s...
Jun 25, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
jhjorten
Jun 28, 2019Aspirant
Current firmware is Orbi 2.3.1.60
Size of home is 3,600 sq feet (I am testing on a Sonos that is within 15 feet of Orbi router)
Distance between Orbi router and Satellite is about 38 feet.
I tried changing channels to 1, 6 and 11 without success.
I do have wifi neighbors, there are about 10 SSIDs that come up when I search for a network.
I enabled Beamforming and WMM and I tried diabling Daisy Chain, Fast Roaming, IPv6..
Still received the same error when trying to play music direct from my Sonos App on my iPhone which is the error loading queue 701. If I try to request Alexa to play music it will play, if I ask Alexa to play music on Sonos it is silent. My current Sonos show connected to the 2.4 ghz channel.
If there are any other ideas or anyone has had success with an Sonos - Orbi - Arris BGW210 it would be great to hear how/if you were able to get it to work.
Thank you!
