sketch8
May 20, 2019Tutor
Orbi RBK 50 Wifi too slow
I have 1gb internet speed. I changed my old rounter with RBK50. I noticed that the speed of wifi is too slow. I am getting around 40mbps download and 15mbps on upload. I tried to speed test on my des...
sketch8
May 21, 2019Tutor
I am getting 320mbps on wired computer. When I tried to connect through WiFi I am getting 40mbps download. I have 1gb internet speed
May 21, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
What devices are you using to wireless speed test?
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- sketch8May 21, 2019Tutor
1. What Firmware is currently loaded? Router Firmware Version
V2.3.1.60
2. What is the Mfr and model# of the ISP modem the NG router is connected too? I am not sure what is this. I am from Japan
3. Is the Orbi system operating in Router or AP mode? Router Mode4. What is the size of your home? Sq Ft? The distance of Router and satellite is just 6-7 meters
5. What channels are you using? 2.4ghz - 11 5ghz -44
6. Any Wifi Neighbors near by? If so, how many? I have on my isp modem i only detect my own wifi at home asside from Orbi
7. What devices are you using to wireless speed test? I am using Iphone with speedtest app and mac using speedtest.net wbsite8. Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM.
Enable Beamforming
Enable mimo
enable Fast Roaming
Enable WMM (Wi-Fi multimedia) settings
9. I tried to disable the daisy chain but i am getting issue with internet connection. it wont connect sometimes it would takes sometimes
10. Fast Roaming - enable or disable same speed too slow
11. IPv6 - disable
12. Set 20/40Mhz Coexistence to 40Mhz only - I dont have this option on only Enable or disable 20/40 MHz Coexistence Currently disable
