NYGFAN106
Jun 20, 2020Follower
Orbi rbk 50
I have been having bad performance out of my product since getting it today. I can run a speed test by login on 192.168.1.1 it usually shows it at 494m downloads and 286 m uploads. Then when I run the...
Jun 21, 2020Guru - Experienced User
Are you speed testing with a wired or wireless device? Wired speed test is preferred to start.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
