Coleyp
Oct 27, 2020Follower
ORBI RBK 50
Hey, I was looking for some advice if possible please? I have just purchased from eBay the Netgear Orbi RBK50 router but not the satellite. I only have a small apartment and wanted to know if I need to purchase a modem to use with the router? If yes, can anyone recommend what modem I should purchase? Many thanks Paul
1 Reply
It depends on your isp. You usually need some type of gateway but it depends on whats compatible with your isp's service. You'd have to contact them
