JimHolman
May 16, 2018Aspirant
Orbi RBK 53 & new CBR40
I own the Orbi RBK 53 package distributed by Costco. This is the combination of an Orbi router + 2 satellites. My question is about the yet to be released new CBR40 combo of a modem & Orbi router. My...
Jun 03, 2018Guru - Experienced User
RBKs are kits, router and 1 to 3 satelllites. Orbi routers only run in router mode or AP mode. They are not designed to be extenders like satellites. RBS models are just that, satellites.
ConstantineP wrote:
Any chance of Netgear releasing update to convert RBK into RBS ?
ConstantineP
Sep 08, 2018Star
What i meant is if i replace my RBK with the new CBR40 can i then flash the old RBK and make it a sattelite to extend network ? Would that be an option ? Thank you
- FURRYe38Sep 08, 2018Guru - Experienced User
The RBR50 in that kit can't be run like a satellite. So no. You can use the RBS satellites from that kit with the CBK kit.
