ShreeMoorthy
Apr 12, 2021Star
Orbi RBK-53 AC3000 Mesh system - Internet access interruptions after latest update V2.7.2.104
Till I updated to the latest firmware V2.7.2.104, everything was OK with using ACL. Now, randomly ACL will stop all internet access (errors like certificate cannot be trusted, etc). The 1st time, I t...
Apr 12, 2021Guru - Experienced User
ACL? not sure what specifically you're referencing.
There has been numerous complaints on the forums about the .104 firmware. the work around is to disable day light savings time and the traffic monitor. Then reboot your device. I'd try that option.
Or you can downgrade the firmware a version.
ShreeMoorthy
Apr 12, 2021Star
ACL - Access Control List. Where you can specifically allow or block devices.
Typical process: you provide folks the SSID and password. Once they connect, you need to go into the router portal 19.2.168.1.0 or whatever... and then "Allow" the device to connect. Essentially this is a 2 step authentication.
You can access the ACL from 2 places:
1. Advanced --> Security --> Access Control
2. Basic --> Home --> Attached Devices --> Click on "Go to Access Control to allow or block devices" on the top-right side
Hope that helps / SM
plemans wrote:ACL? not sure what specifically you're referencing.
- plemansApr 12, 2021Guru - Experienced UserFully realize what the access control is.
Just wasn't sure what exactly you were abbreviating. Always safe to check. đ - ShreeMoorthyApr 13, 2021Star
Thanks. Will try that.
ShreeMoorthy wrote:ACL - Access Control List. Where you can specifically allow or block devices.
