ShreeMoorthy
Apr 12, 2021Star
Orbi RBK-53 AC3000 Mesh system - Internet access interruptions after latest update V2.7.2.104
Till I updated to the latest firmware V2.7.2.104, everything was OK with using ACL. Now, randomly ACL will stop all internet access (errors like certificate cannot be trusted, etc). The 1st time, I t...
Apr 12, 2021Guru - Experienced User
Perform a full factory reset on both router and satellite(s) then set up from scratch.
- vajimApr 13, 2021Master
FURRYe38 wrote:Perform a full factory reset on both router and satellite(s) then set up from scratch.
Why does your response not mention V2.7.2.104?
- ShreeMoorthyApr 13, 2021Star
Will try that as the last resort, I suppose. Thanks.
- FURRYe38Apr 13, 2021Guru - Experienced User
Let us know how it goes. Be sure to disable Traffic Meter after the factory reset. Just don't enable it.
Thanks much. Will do. Have to wait for the kids' online exams / finals to be over... till then I cannot take a chance, else I'll have another set of problems to contend with :smileyvery-happy:
