ShreeMoorthy
Apr 12, 2021Star
Orbi RBK-53 AC3000 Mesh system - Internet access interruptions after latest update V2.7.2.104
Till I updated to the latest firmware V2.7.2.104, everything was OK with using ACL. Now, randomly ACL will stop all internet access (errors like certificate cannot be trusted, etc). The 1st time, I t...
Apr 12, 2021Guru - Experienced User
Perform a full factory reset on both router and satellite(s) then set up from scratch.
ShreeMoorthy
Apr 13, 2021Star
Will try that as the last resort, I suppose. Thanks.
FURRYe38 wrote:Perform a full factory reset on both router and satellite(s) then set up from scratch.
- FURRYe38Apr 13, 2021Guru - Experienced User
Let us know how it goes. Be sure to disable Traffic Meter after the factory reset. Just don't enable it.
- ShreeMoorthyApr 13, 2021Star
Thanks much. Will do. Have to wait for the kids' online exams / finals to be over... till then I cannot take a chance, else I'll have another set of problems to contend with :smileyvery-happy:
