alios69
Mar 12, 2019Follower
Orbi RBK 53 ethernet backhaul switch problem
After Compliments,
I am having an issue with 2 houses with the orbi router, satellites, modem and switch.
So here is the lay out.
I have a have a Hauwei HG8245H Modem.
This is connected to a...
ekhalil
Mar 12, 2019Master
Both the modem and the ORBI router have DHCP turned on.
I agree with FURRYe38, this is a clear double DHCP and double NAT issue. You have to choose either the Huawei router or Orbi as the main network router, otherwise beside that your devices will be belonging to two different separated networks, many services will not be able to survive passing through NAT twice.
