JJSnels
Jun 30, 2020Aspirant
orbi rbk 53 ip adress, how to change
Hi, I notice I can not change the ip address of my Orbi 53 (only app?!?). I am connected to a Zyxel T-50 modem. They both have the same ip-address and that gives problems with a lot of websites. Tha...
Jun 30, 2020Guru - Experienced User
What mode is your ISP modem working in? I believe it has a built in router already. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Any IP address changes need to be effected using a web browser connected to the RBRs web managmenet page at orbilogin.com
JJSnels
Jul 01, 2020Aspirant
Thanks for your prompt reply. I will discuss the possibilities with my ISP.
The model is: VMG8825-T50
