JJSnels
Jun 30, 2020Aspirant
orbi rbk 53 ip adress, how to change
Hi, I notice I can not change the ip address of my Orbi 53 (only app?!?). I am connected to a Zyxel T-50 modem. They both have the same ip-address and that gives problems with a lot of websites. Tha...
CrimpOn
Jun 30, 2020Guru - Experienced User
JJSnels wrote:Hi, I notice I can not change the ip address of my Orbi 53 (only app?!?). I am connected to a Zyxel T-50 modem. They both have the same ip-address and that gives problems with a lot of websites.
Can you please report the entire product model number? When I search for "Zyxel T-50", it appears that there are a number of Zyxel products which end in T-50.
JJSnels
Jul 01, 2020Aspirant
Hi, The model is VMG8825-T50
