rexmos
Jul 04, 2018Aspirant
ORBI RBK 53 WiFi slower on router than satellites
Installed my RBK53 yesterday, Firmware auto updated to latest version. Unfortunately my phone access point is in one corner of the house, so not an optimal Router location. My problem is that the dow...
- Jul 04, 2018
Be certain that both the router and satellite are running the same firmware. If not, update the satellite first, then the router. Reboot the router then reboot the satellite.
WiFi signals will NEVER be as fast as hardwire ethernet. Most of the speed loss is from interference and inherent latency. Check the channels of both the 2.4 and 5 gHz bands. Do not use "auto" channels seltection. Try channels 1, 6 or 11 for 2.4 gHz and 40, 44, 48 for 5 gHz. Alternatively, you could run a diagnostic program on your desktop to see which WiFi channels are clearest (Mac OS has a built-in test, Windows requires a 3rd party app.).
Good Luck!
tucsontico
Jul 04, 2018Virtuoso
Good Luck!
rexmos
Hi tucsontico
Thanks, that worked fine. I used the MacOS diagnostic tool to find the best channels, applied them and Hey Presto Router speed is now the same as the satellites.
Many thanks for your help
Rexmos
