TRT1
Nov 16, 2020Aspirant
Orbi RBK 53 wrong firmware
My RBK53 is currently running 2.7.0.70. This is apparently a USA only version of firmware, but I live in Australia. How do I switch to the international version? I see that the 2.7.0.70 version h...
- Feb 05, 2021
Updated to latest firmware: 2.7.2.104. Seems now that no separate USA-only version exists, the update process works smoothly.
Nov 18, 2020Guru - Experienced User
You can try this:
"1) Go to Advanced, Security, Block Sites and add the following sites.
http.fw.updates1.netgear.com
downloads.netgear.com
Kept digging on this and learned the following:
TCP port 443 (HTTPS): http.fw.updates1.netgear.com
TCP port 21 (FTP): updates1.netgear.com
I believe those two are all that's necessary to block. Orbi tries HTTPS first, then FTP."
https://community.netgear.com/t5/Orbi/Firmware-auto-update-domain/m-p/1499659/highlight/true#M22873
To do this right, you would first need to downgrade the RBS and RBR back to v2.6. Reset and this time, setup the RBR from scratch while it's disconnected from the ISP services/modem/ONT. Or disconnect the RBR from the modem services before you update. Once you have completed the RBR setup wizard, go in and set these block site configurations on the RBR. Once you have it all entered in and saved. Reboot the RBR, when the RBR reboots, plug in the RBR back with the ISP services, modem or ONT. This should block the update from happening...
TRT1
Feb 05, 2021Aspirant
