TRT1
Nov 16, 2020Aspirant
Orbi RBK 53 wrong firmware
My RBK53 is currently running 2.7.0.70. This is apparently a USA only version of firmware, but I live in Australia. How do I switch to the international version? I see that the 2.7.0.70 version h...
- Feb 05, 2021
Updated to latest firmware: 2.7.2.104. Seems now that no separate USA-only version exists, the update process works smoothly.
TRT1
Feb 05, 2021Aspirant
Feb 06, 2021Guru - Experienced User
Yes, I was told by NG that v104 is for everyone.
- TRT1Feb 06, 2021AspirantThanks for the help. At least I now feel better about diving into manual updates.
- FURRYe38Feb 07, 2021Guru - Experienced User
You'll be fine with manual updates, use a wired PC and either use IE11, Edge or Firefox for doing the udpate.
I've been doing manual FW udpate for years. No problems with it.
I recommnend a full power OFF for 30 seconds of the RBS and RBR after the FW is fully processed by the units then back ON with the RBR first then RBS lastly. I haven't seen any issues using this process. Some have seen odd issues so as last resort, a factory reset maybe needed.
Be sure to make a backup configuration to file for safe keeping after the new FW is loaded and the system is tested as working well. Saves time if a reset is needed later on.Good Luck.
TRT1 wrote:
Thanks for the help. At least I now feel better about diving into manual updates. - BoilerPlateFeb 07, 2021Apprentice
The truth is your mileage may vary. >vajim. User beware. :smileysad:
