cyoung01
Sep 16, 2020Aspirant
Orbi RBK Satellite Static IP
Hi all, looking for some guidance with my RBK Orbi system. I have a series of Amcrest IP Cameras around the house and have trouble with connection. I finally was able to set the cameras default gatew...
Mstrbig
Sep 16, 2020Master
Go into your camera setup and choose an IP address for each camera with in your DHCP server's range.
Then you can go to tje WEB portal orbilogin.com > Advanced tab > Setup > LAN Setup > Address Reservation and add those IP addresses for the cameras or any other devices you want to have static IP. You will need the MAC address and IP address for each camera in order to complete this.
cyoung01
Hi there, thank you for the reply. The IP on the camera settings are already configured as static, which feed to a NVR. That NVR has been port forwarded. Do I need to do the steps you listed for the satelite to make it static? Trying to make the default gateway from camera connect to a specific satellite without the satellite changing IP Adresses from a reboot. Thank you!
- CrimpOnSep 16, 2020Guru - Experienced User
cyoung01 wrote:Do I need to do the steps you listed for the satelite to make it static?
Exactly. Only the Orbi router has an option to define a "Static IP" on the router itself.
Orbi satellites always request an IP using DHCP, so entering their MAC addresses into the LAN Setup table will guarantee that the router always gives them the same IP address.
