SethOx
Nov 09, 2020Guide
Orbi RBK12 - question about setting up bridge mode on combined router/modem
Hi, I'm trying to set up bridge mode on my combined router/modem to use with my Orbi RBK12. My ISP isn't able (i.e. won't) help me to set up bridge mode, so in the end I successfully set up the DMZ s...
- Nov 10, 2020
Good to hear. Please mark your thread as solved so others will know.
Enjoy. :smileywink:
Nov 09, 2020Guru - Experienced User
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Check to be sure the ISP modems IP address doesn't conflict with the RBRs, 192.168.1.1. IF it does, you should beable to factory reset the RBR and walk thru the setup wizard while it's connected to the modem and it should change this for you or you can manually change it on the RBRs web page using a web browser. Or you can change the ISP modems IP address to something else, like 192.168.2.1...Then leave the RBR at 192.168.1.1.
- SethOxNov 09, 2020GuideHi, thanks for your reply. It’s a Technicolor DWA0120.
- FURRYe38Nov 09, 2020Guru - Experienced User
Thankl you for confirming the modem model. :smileywink:
You can do a search online to see if that model pulls up any kind of bridging information. Might ask the mfr about this as well.
- SethOxNov 09, 2020GuideHi, after Googling I found some instructions from a different ISP (Zen) for putting the Technicolor TG589vac router into bridge mode (apparently my router DWA0120 is a direct replacement for the TG589vac, so I guess these instruction also apply for mine?) I’ve attached a screenshot showing the relevant bits of the instructions. You can clearly see the same warning disabling the auto sensing of the WAN interface. If they say to go ahead despite this warning, does that mean it’s ok?
My question is generally whether or not disabling auto sensing of my WAN interface is going to mess anything up? I have no idea of what this means or what the implications are, and I’m just trying to check if I can safely do this
