Lakramir
Jul 12, 2022Aspirant
Orbi RBK12 5GHz Security Issue -> No Password
I Just bought this RBK12 Set NEW. After Setting up the Router and the Satellite everything worked fine until i noticed the 5GHz Wifi is marked as "Open"/Not Protected on my PC. Ive been searchi...
Jul 12, 2022Guru - Experienced User
The RBK12 is a mesh system. and it doesn't have the ability to separate out the 2.4ghz ssid from the 5ghz ssid.
You literally set one name and one password for it. If the 2.4ghz has a password, the 5ghz will to.
It shouldn't show up separate on your network either unless you're using a 3rd party scanner like inssider.
So whats actually telling you it doesn't have a password.
Lakramir
the 5GHz Network shows up with the SSID i Setup just with an 2 Behind it and its defenitely not Secured since i could Connect to it from an Device which was not Connected to the 2,4GHz nor the 5GHz before...
On Every Device where the 5GHz shows up there is no "lock" Sign while on the Others there is an "lock" Symbol...
Which says for me its not Secured at all..
I was Able to Connect to the 5GHz Network without Password while the 2,4GHz got an Password "pop up"/ ...
Just the Generic Android Settings such as my Windows WLAN Settings no special Scanner or Software was used...
i dont know if i can trust this Device...
- plemansJul 12, 2022Guru - Experienced User
What firmware are you on? (for router and satellites)
What modem/gateway are you connecting it to?
If you log into the router through the browser, what does the wireless settings page show?
- LakramirJul 12, 2022Aspirant
Ive Hardreset the whole thing ... and Set it up with the Default Settings now it shows up on Different Phones as one Network with 2,4G/5G instead of 2 oh man <_<
Router Firmware is V2.7.3.22
where do i Lookup the Satellite Firmware ?The Wireless Page looks the Same in Basic and Advanced ? 🤔
Seems like it working as intended now? 😅 would be nice to have some more Informations for later Troubleshooting 😅
- KevinLiTJul 12, 2022NETGEAR Moderator
Hello Lakramir,
I understand that you would like information on where to find the most recent firmware for your Orbi Mesh RBK12.
Please navigate to the link below for the most recent firmware for your RBK12:
https://www.netgear.com/support/product/rbk12.aspx#download
Best,
Kevin
Community Team
