Lakramir
Jul 12, 2022Aspirant
Orbi RBK12 5GHz Security Issue -> No Password
I Just bought this RBK12 Set NEW. After Setting up the Router and the Satellite everything worked fine until i noticed the 5GHz Wifi is marked as "Open"/Not Protected on my PC. Ive been searchi...
Jul 12, 2022Guru - Experienced User
What firmware are you on? (for router and satellites)
What modem/gateway are you connecting it to?
If you log into the router through the browser, what does the wireless settings page show?
Lakramir
Ive Hardreset the whole thing ... and Set it up with the Default Settings now it shows up on Different Phones as one Network with 2,4G/5G instead of 2 oh man <_<
Router Firmware is V2.7.3.22
where do i Lookup the Satellite Firmware ?
The Wireless Page looks the Same in Basic and Advanced ? đ€
Seems like it working as intended now? đ would be nice to have some more Informations for later Troubleshooting đ
- KevinLiTJul 12, 2022NETGEAR Moderator
Hello Lakramir,
I understand that you would like information on where to find the most recent firmware for your Orbi Mesh RBK12.
Please navigate to the link below for the most recent firmware for your RBK12:
https://www.netgear.com/support/product/rbk12.aspx#download
Best,
Kevin
Community Team
