Samuelgyc
Jun 20, 2020Aspirant
Orbi RBK12 Connected but no internet access
Hi all, I just bought an Orbi RBK12 about 6 hours ago and had it installed and reinstalled several times via the app. However I am connected but without any internet access. I am currently using a ASU...
CrimpOn
Jun 20, 2020Guru - Experienced User
Samuelgyc wrote:
Hi all, I just bought an Orbi RBK12 about 6 hours ago and had it installed and reinstalled several times via the app. However I am connected but without any internet access. I am currently using a ASUS GT-AX11000 Router for about 3 days, brand new. Please help!
I am wondering what the purpose is of adding a cheap Orbi WiFi system to a $400 "Top of the Line" Asus AX WiFi system, since it appears that both are providing WiFi.
The Orbi RBR10 (router) "Internet Port" is connected with an ethernet cable to one of the ethernet ports on the Asus, correct?
Does the Orbi show up on the Asus display of "connected devices"?
What IP address does the Asus show for the Orbi?
The convention thinking on this forum is that having "two routers" is generally not a good strategy. Netgear describes the situation like this:
https://kb.netgear.com/30186/What-is-Double-NAT
The most obvious step is to use the Orbi web interface to change the Orbi from "router" to "Access Point" (AP) mode. This is on the Advanced Tab, Advanced Setup, Router/AP Mode.
- SamuelgycJun 20, 2020AspirantHow do I access orbi web to change the settings?
I'm very new to this- CrimpOnJun 20, 2020Guru - Experienced User
Use a web page to connect to the address: http://orbilogin.net. Although I believe that the RBR10 may have a "special" admin login.
Here's the User Manual: https://www.downloads.netgear.com/files/GDC/RBK12/RBK12_13_14_UM_EN.pdf
Look on page 19.
